ok, so im adding a solar setup to my remote pavilion... it will run a car radio and a handful of led lights. I dont think ill be using much power at all.
i already have a renogy 100w panel a SolarEpic EPEVER 20A MPPT Solar Charge Controller
I had planned on putting the panel on the roof of the pavilion, which is pretty shaded. It was convenient, and i think it might get the job done... if not, i could add a 2nd or 3rd panel...
but... someone suggested doing a longer run and putting the panels out in the field 125' away which would give it considerably more light. However, this being a budget build, i dont want to spend a fortune on wire. I do have a ton of 12/2 uf wire.. im unsure if the line loss would be acceptable. the way i figure it, as long as im not loosing 50%, id still be getting more energy to the charge controller than the shaded panel. I am aware that i cant have the voltage drop below 14v or there abouts.
when running this line loss calculator, i am unsure what volts and amps to put in for my panel... and im also unsure of what % drop is acceptable, and what end of line voltage is acceptable.
thanks!!!!
thanks!!!!
