i have a trailer with a dual battery, 400W 12v system and an RV with a dual battery 12v unknown W system (3 panels). They both have their own controllers.
They both have inverters, the RV at 400W and the trailer at 2000W. I plan to swap the RVs 400w to the
When I am parked I would like to join the systems at the DC battery level. So technically the inverters are a moot point.
Primarily it would be to take the RV as master. I would expect both systems to be equally healthy and balanced at roughly the same battery levels.
I realize there could be issues having dual controllers, but that is the configuration I have as each is to be standalone systems.
Please advise any technical issues I may have and suggest the proper mechanical connection apparatus I should use.
thank you,
Mike
thank you,
Mike
