Hello, I have a 400 watt 355 amph setup on my conversion van. The charge controller is a 30 amp PWM, batteries are agm deep cycle. About 2 weeks ago my charge controller started fritzing on the voltage display. It would change sporadically between 19v and 8v every second. It stopped charging the batteries at all. Originally I thought this was an issue with the charge controller. I checked all the wires with a multimeter and everything seemed fine. The solar panels were bringing in 17V on a nice sunny day. The batteries were at 12.4 (a little drained). Everything seems hooked up fine.
Windy Nation sent me a new charge controller, exactly the same as the old one. PWM 30 amp. I connected it carefully, making sure to connect it to the batteries first and it shows the same display as the old one, fritzing between numbers 8v-19v
I'm not sure what troubleshooting steps to take from here. Is there a way to check each solar panel to see if there's an issue? Has anyone come across this problem before? Could it be a wiring problem?
I truly appreciate any advice. Been without power for a while and would really like to have a fridge again. Thank you!
-Tes
-Tes
