Panels have arrived!
Starting point:
No space. Made battery bank with 3/4" plywood sides, 1.5" bottom and diamond plate. Pretty tight even if it does add 700 lbs of tongue weight.
To the roof. Who says you can't install 1.9k on an RV? 180" welded unistrut.
Homemade roof brackets every 30". Add 1/4" steel lengths between the two for raising panel. More Dicor on its way..
Electronics, only space available. Housing water and slider pump.:
Cut to size and added insulating and sound boards.
Moved water inlet to other side of camper. New door, added venting. Maybe I'll paint its edges white:
Starting point:
