I have a MPPT e-SMART Solar Charge Controller 12V 24V 48V 40A. what size, and how many panels can I use with this controller?
Announcement
No announcement yet.
Solar Panels
What battery voltage will you be using ?
Did it not come with a manual? Most reputable controllers have a web site with a panel calculator on it.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
To figure this out, you need to calculate how many voltage from the solar panels first, in order to make sure the reg doesn't get overload and fry itself.
For example, my reg is 50V tolerant, that means whatever 12V, 24V, 36V system it is building up, the input voltage can not exceed 50V, otherwise the reg will be damaged.
Next, you should read the voltage output from the solar panels with an electrical devices like a multimetre, this is to confirm the practical voltage of the panel first of all, very important. It's the way of wiring decide how many voltage the panels put out, to be noted that wiring in series will double the voltage.
Remember the reg will smart read your battery voltage, but give it a reasonable voltage difference to make up. A good reg will bring down 36V from the panels to 24V and charge your batteries, but do not make it more than 20V according to my practical conclusion.
36V solar panels to charge 24V batteries;
20-24V solar panels to charge 12V batteries.
You can never make 12V panels to charge 12V battery, as most people think it would happen.
Originally posted by gustavpumper View Post...You can never make 12V panels to charge 12V battery, as most people think it would happen.I'm an RV camper with 470 watts of solarComment
Originally posted by ewarnerusa View PostThis is wrong. A 12V panel has a nominal voltage around 18V and works just fine to charge 12V batteries. I've been doing it for a few years now. Calling the panels "12V" is just nomenclature to describe the setting they're intended for.
It could be that gustavpumper may trying to explain that a panel that only produces 12 volts can never charge a 12volt battery. As well as a panel that only produces 24 volts will never charge a 24 volt battery.
People get confused when the nomenclature of panels (12volt, 24volt, grid-tie, etc.) are used instead of the actual specifications. That gets them all messed with figuring out how to wire up panels in series or parallel to charge their battery systems.Comment
