I have been attempting to research and figure this out but it seems to be a case of the more I know the less I understand. I'd like to add solar to my RV. I'm sure my questions are ridiculous for someone experienced but any guidance would be appreciated.
I was given an 800w solar panel. I also have a 2500w inverter. I realize I need a controller and probably another battery (i have one that holds 120ah I believe.). I'm getting confused about what situation you would need a 24v rather than 12v system. I am assuming that 12v is what I'd need since my inverter works on 12v. Im not sure about the solar panel but it seems with the converter it would work it out? I found a converter on amazon and am wondering if it would work: https://www.amazon.com/dp/B005FDU6SS...=I7IS6U5Z8MN15
The prices on converters really vary and not sure if one on the cheaper end would be ok. Also do converters stop charging until the battery voltage drops or do I need to also put a switch to stop charging once full?
