Hello all,
New member here from Belgium. I'm working on a solar system for a horse carriage/mobile home project, it has all the comfort off a RV, except it's pulled by a horse .
Before i did extensive traveling on a boat with a small plug and play solar system, just running a small fridge in the summer time, but now this project has a bigger scope.
There's a fridge, lights, a radio, some sockets for chargers and such.
I appear to be a bit in over my head: i ran into a problem, hope to find help here.
Here's what i have: two 48-cell panels on top of my carriage running into a regulator and a single 12v solar battery (weight is an issue with the horse...). Attached is a image of the set-up.
I used wires delivered with the panel for connections from the panels and to the battery, and thick wires, the type you would use for a washing machine, for the electrical circuit
The regulator is shunt type and has a 15 ampere push-fuse inside. No other fuses anywhere.
For the moment i have only one 3.5 watt 12v lamp installed.
Once i fire up the lamp, whether i do it with all the wiring attached like in the first image or directly with a short (+/-50cm) wire like in the second image, the lcd on regulator peeks the load bars for a second, then i immediately get an over-current error.
The regulator manual says this about it:
Overcurrent
Load
load
current is too
high
And it states that as a protective measure the controller disconnects the load, however, after this, in spite of keeping the error message, the lamp stays lit.
I tried to hook up a second lamp, same thing 3.5 watt 12v, and the fuse blew, although that might be unrelated cause it also blew when i attached just that lamp and not the other one.
I also attached the manual for the regulator.
Multimetering around the different wires doesn't show any short circuits.
Also i really paid attention to polarities and stuff, so i don't think the problem is there neither...
Does anyone know what i am doing wrong?
Any other tips on how to make this system as safe and efficient as possible are also welcome.
The fun part of the story is: i'm moving into this thing in about 11 days
Any help is much appreciated.
Best
Tony
Overcurrent
Load
load
current is too
high
Best
Tony
