I have some questions regarding an emergency solar setup that I plan on building. I have enough money to purchase 2 x 100 watt mono solar panels (http://www.amazon.com/dp/B00BCRG22A/ref=cm_sw_su_dp), which includes a 30 amp PMW charge controller, branch connectors, and cables. I want to produce approximately 1000 watt hours per day, which would require 2000 watt hour battery capacity (using the 50% rule; calculation does not account for multiple days of operation). Therefore, my 12 volt battery bank would require 167 amp hours (2000/12). I plan on purchasing 2 x 105 amp hour batteries to store this energy. I live in NC and figured for 5 hours of sunlight. Please keep in mind this setup is only for emergency situations so I don't want to spend a great deal on it.
Questions:
Mike
Questions:
- Any suggestions, corrections, recommendations on my specs above?
- What wattage power inverter is recommended for this setup?
- I plan on building this as a portable setup on wheels and anything plugged in would be within 10 feet. The solar panels would be within 10 - 20 feet. What gauge wires do you recommend from the charge controller to the batteries? And what gauge wires to connect the batteries together? And what gauge wires from the batteries to the inverter?
- Do you recommend fuses? If so, how many, where and what types?
Mike
