Ok so I found cells the put out 4.35 Watts .5 Volts and 8.7 Amps a cell.
Im starting to think that the listing is incorrect
I would like to do a 24v system and thats fine at first 48 Cells at .5 volts=24Volts. Well this is where I get lost.
48 cells parallel x .5volts=24v Great
48 cells parallel x 4.35watts=208.8 Watts Great
48 cells parallel x 8.7 Amps= 417.8 Amps Not great
If you look at 417.8Amps x 24volts=10027 Watts
and 208.8 watts / .5 volts = 417.8 amps
I'm not sure if the listing is correct but I don't think they make a Solar Regulator to handle 417.8 Amps
I would like to run 30A Solar Regulators
Am I loosing my mind or did I forget something.
or Does Amps stay the same under a parallel connection?
