  • Filter
  • aliropm
    • May 2010
    How to build a 1000W of power output
    Greeting from Chile. I am new in this area, Please could you help me in this request. I am building my own solar energy system. I only need 1000W of power base on 12v volt.
    Can you tell me onw many watts of panel do I need.
    How many amperes needs the controller charger
    How many watt do I need for the converter
    and how many batteries do I need for the bank.
    All comment are very wellcome.
    thanks in advance
    Aliropm
    Well your question does not make much sense. If you need 1000 watts out from the panel, then you need at leat a 1000 watt solar panel.
    I think you are mixing up power and energy.
    Watts = Power at any given moment in time and is an instatanious measurement or expression.
    Energy= is the amount of power over a given amount of time. In electricity it is expressed as Watt-Hours. Watt-Hours = Watts x Hours
    • BuzzBuds
      • May 2010
      • 64
      I guess sunking is saying is for how long do you need the 1kw for.
      I also thinkI am new to all this too but that would fall onto the size of battery pack you have set up, providing your solar panel can suply the correct amount energy to keep battery pack charged for night time use?
      • MarineLiner
        Solar Skipper
        • 656
        Originally posted by BuzzBuds View Post
        ... would fall onto the size of battery pack you have set up, providing your solar panel can suply the correct amount energy to keep battery pack charged for night time use?
        • BuzzBuds
          • May 2010
          • 64
          [QUOTE=MarineLiner;9488]
          • MarineLiner
            Solar Skipper
            • 656
            - try and aliminate as much on battery dependacy is a good policy but I am not talking about a large just 2 of them how else will you store the power to use after dark? or are you just sujesting that he should not use the radio at night?
              • MarineLiner
                Solar Skipper
                • 656
                Originally posted by Sunking View Post
                Well battery efficiency is around 80 to 90%.
                Pump back tanks are on the order of 25%.
                  Actually it is quite old technology and used by hydro electric utility companies. During power generation using dams, you take the unused generating capacity to run pumps to pump water into a lake to later be released and generate power again.
                  Same thing can bee applied with a elevated water tank. You pump water up in the tank, and release it later to generate electricity. Sound cool but really inefficient.
                    Plus the volume of water required per kW generated is rather large.
                    • MarineLiner
                      Solar Skipper
                      • 656
                      • MarineLiner
                        Solar Skipper
                        • 656
                          Something similar to the following (from another site):
                          (head(in ft) X GPM) / 10 = output in watts for a standard micro-hydro unit. So (10 (ft) X 100 GPM)/10= 100 watts. And with 1000 gallons this will last 10 minutes. 100 ft x 100 GPM = 1kVA which is about what an average US house needs. 100 GPM X 60 min X 24 hours = 144000 gallons per day.
                          or
                          In very rough numbers, a 1000-gallon tank 100 feet high could store about 3-4 kwh
                          • MarineLiner
                            Solar Skipper
                            • 656
                            Make a new topic
                            Thank you very much.
                            i make a new topic:
                            Water Tank vs Battery Bank ? - Solar Panel Help Desk
                            If you are a homeowner who is about to put a solar panel system on your home or you are a newbie to the solar market, get started here! A non-technical forum to help you understand the in's and out's of solar.
                            as we won't make ourself out of topic here.
                            • BuzzBuds
                              • May 2010
                              • 64
                              [QUOTE=MarineLiner;9525]
