I would like to setup a solar system to power a 1 HP well pump.
The pump is single phase 230 vac and draws 8.3 amps at full normal load.
Question: Can two 12vdc X 110vac be wired in series to feed 220vac to the motor
Noticed that the 24vdc/220vac or 12vdc/220vac inverters are 50 Hz.
Will the 220 vac/60 Hz motor run on 220 vac 50 Hz?
