I am thinking of constructing a small and simple 200W system with a 1kwh batteries (rated at 8 hour discharge).
Excluding the inverter variable (meaning, I could potentially install an inverter that can handle thousands of watts), what can this little system do?
Given a 50% discharge / day, I can only use 500-wh.
I want to be able to run the basic peripherals (meaning, not the heavy appliances - Washer/Drier/Vacuum/AC/Fridge).
