Can 12v LED lights be used in track or cable kits with power from batteries in 12v configuration? Do you simply do away with the transformer since power source is already 12v? Can any light fixture with the same base be used with 12v supply?
12V LED Track Lighting
Sure, you just keep buying batteries as they die.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
