Originally posted by green_regards
View Post
AC Submersible Pump
[SIGPIC][/SIGPIC] -
AC pump
Originally posted by Brijesh View Posti have 2 X 3HP Falcon submersible pumps and want to run Solar On Grid. Could anyone help me how much watt solar panel, how much kwh inverter will require and other parts ?
For single 3 Hp pump
solar panel-2.5Kw
Inverter -3KVA
Mod note - No advertising allowedLast edited by russ; 04-23-2014, 02:24 AM.Comment
Consider using Grundfos SQ pumps to eliminate the startup load issue. Or create your own similar system with a VFD, 3 phase motor and a controller.Comment
Originally posted by jon_r View PostConsider using Grundfos SQ pumps to eliminate the startup load issue. Or create your own similar system with a VFD, 3 phase motor and a controller.[SIGPIC][/SIGPIC]Comment
Originally posted by russ View Postjon - tell us about your qualifications to be making recommendations?Originally posted by jon_r View PostConsider using Grundfos SQ pumps to eliminate the startup load issue. Or create your own similar system with a VFD, 3 phase motor and a controller.
I'm trying to connect an ABB VFD with a solar firmware version to power a 3HP 3 phase pump.
Anybody has any experience with that?Comment
