View Post
Residential Energy Storage Hub
Originally posted by SunEagle View PostDo you think the PbC batteries being used in the RES HUB are the ones or similar to those being tested by Sandia?MSEE, PEComment
Originally posted by inetdog View PostIt is not completely clear from their diagrams whether the PV power is used for recharging the battery or just for supplementing the UPS output while on battery.MSEE, PEComment
Originally posted by Sunking View PostYou answered your own question. 10% = 10 hours, 20% = 5 hours.
That said - the Rosewater "HUB" marketing sheet leaves out a lot of data needed to know exactly how this would run.Comment
Originally posted by IntrusDave View PostI've never seen a single UPS with a linear runtime.MSEE, PEComment
Sinking, Derek, the green line is NOT the PbC. It is the ultrabattery and that is most certainly NOT the same thing as the PbC.
The PbC does not have a lead-carbon negative electrode like the ultrabattery.
The negative electrode in the PbC is ALL carbon and that makes a HUGE difference.
DComment
Originally posted by Dragon View PostSinking, Derek, the green line is NOT the PbC. It is the ultrabattery and that is most certainly NOT the same thing as the PbC.
D[SIGPIC][/SIGPIC]Comment
The five entities that are actively developing lead-carbon battery technology are:
- MeadWestvaco (MWV), a packaging material and container manufacturing company that is developing activated carbon additives for the lead sulfate pastes used in conventional lead-acid batteries;
- Australia’s Commonwealth Scientific and Industrial Research Organisation (CSIRO), which has developed a split-electrode lead-carbon battery that it calls the Ultrabattery;
- Japan’s Furukawa Battery (Frankfurt - FBB.F), which licensed the Ultrabattery technology from CSIRO and has successfully road tested its device for 100,000 miles in a modified Honda hybrid;
- East Penn Manufacturing, a privately held manufacturer of lead-acid batteries that is using carbon additive pastes in experimental batteries and has recently acquired an exclusive U.S. sublicense to manufacture the Ultrabattery from Furukawa; and
- Axion Power International, a small manufacturer of lead-acid batteries that has developed a formidable U.S. patent portfolio in lead-carbon battery technology that will begin commercial production later this year and has partnered with Gaia Power Technologies for a NYSERDA funded utility substation support project that was discussed in the DOE’s 2008 Peer Review.
Cycle-life test results for the MeadWestvaco and East Penn batteries with carbon-enhanced pastes are both included in the Sandia graph, as are test results for the split-electrode CSIRO-Furukawa Ultrabattery. While Axion didn’t participate in last year’s tests,
All that SPLIT ELECTRODE means is one electrode is made of Lead, and the other is made of Carbon aka PbC. Ultra Battery is just a marketing gimmick.MSEE, PEComment
All-carbon Axion negative electrode is a game-changer
Sunking (Derek),
The principle point of failure in a lead-acid battery is the lead negative electrode. The Ultrabattery has a split negative electrode, half of which is still lead and will still experience sulfation and failure very similar to a plain old lead-acid battery.
The PbC has no lead negative electrode, it is made of activated carbon which does not sulfate.
The carbon negative electrode in the PbC is the reason it has tested to 100,000+ cycles using a test protocol jointly designed with BMW, compared to about 10,000 cycles with the best AGM battery.
Please do not take my word for it though. You can follow this link to the presentation that Dr. Enders Dickinson made for the 13th European Lead Battery Conference just last year.
http://www.axionpower.com/Presentations
"Dr Dickinson emphasized that the total absence of plate sulfation in PbC batteries, which have no-lead pure-carbon anodes, is a critical differentiator in comparisons with traditional or advanced VRLA lead-acid batteries."
DComment
Originally posted by russ View PostAny references about hat?
Thank you,
DComment
Originally posted by Dragon View PostRuss, please see my comment just below. I was just trying to clarify for everyone, in case there is confusion, that Ultrabattery and the PbC are most certainly NOT the same thing.
Thank you,
D
As far as I can see they are simply flogging Rosewater's unit?[SIGPIC][/SIGPIC]Comment
Originally posted by russ View PostI get their routine emails - The web page you linked to is new I believe.
If you are referring to the Residential Energy Storage Hub:
Rosewater was involved very early in conceptualizing and defining it and is primarily responsible for marketing it and managing it from the distributor-customer perspective.
Axion Power engineered the residential-energy-hub, built the prototype and manufactures its PbC batteries including the critical activated-carbon negative electrodes which have a dedicated robotic assembly line.
For the overall product, Axion Power has stated that it may look to outside specialist companies if needed for large quantity assembly – which is obviously not the best and highest use of its advanced battery facilities and scientific/engineering staff.Comment
Simple problem. All of Axiom claims cannot be verified. They refused to have 3rd party test. The technology exist. Three other manufactures other than Axiom offer the same technology and have had 3rd parth testing like Sandia National Labs.MSEE, PEComment
It seems Axiom is just sticking it's fingers in many things that others have developed hoping that something pans out. Their technology changes every few months?
If they won't go to Sandia with their unit then it must either be vaporware or pure hustle.[SIGPIC][/SIGPIC]Comment
