All Set to make a Solar Panel. Require some informtion
[URL="http://www.gaisma.com"]www.gaisma.com[/URL] -
Originally posted by mcc View PostI was checking the panels today. I connected 2 panels, 72 cells configured at 18v, with 20 ampere charge controller. As soon as I connect the panels, the voltage drop at 12.7vol Open circuit voltage is 20.7volts. Why its happening?
PWM CC are just a switch that connects your panels to the battery. Al PWM chargers Input Current = Output Current. 20 amps in = 20 amps out. Solar panels are current sources, not power voltage sources. That it is why it is possible to say hook up say a 240 watt panel with a rating of 36 volts Vmp, 6.6 amps Imp (a typical Grid Tied 72 cell panel, and only get 12 volts x 6.6 amps output (79 watts) at best on a PWM CC. Surprise!
Just think you could have bought a MPPT charge controller and that same 18 volt 20 amp panel would output 12 volts @ 29.1 amps from the CC.MSEE, PEComment
Friends, can you please suggest me which junction box should I buy? I see two types of JB, one with only two metal connecters and one with four metal plates.Comment
Originally posted by mcc View PostFriends, can you please suggest me which junction box should I buy? I see two types of JB, one with only two metal connecters and one with four metal plates.NABCEP certified Technical Sales Professional
