My plan and thanks
Thank you so much for your reply. This is so helpful as I want to do this wiring tomorrow. I will run neutral wire from inverter to ac disconnect but I will not setup the ac disconnect switch to disconnect the neutral. I will just put a neutral bar in the ac disconnect and connect the neutral wire from the inverter to it and then I will run a second neutral wire connected to the same neutral bar in ac disconnect and run it to the neutral bar in the electric service panel. Could you let me know if this makes sense? thx!
