I have loads running on 230V, 50Hz AC at my residence. In case of power failure from the utility, i have a back up with a 135 Ah Lead Acid battery along with a 800VA UPS which switches on almost instantly. On resumption of supply from the utility, the battery gets charged. Now i am planning to install a solar panel and connect the output from the solar panels (DC) to the battery for battery charging. This charging will be in parallel to the normal charging available from the UPS (utility AC supply). The preference of charging will be of the solar supply. Another question is that is there any method available that i can charge my battery along with the supply of the loads.
I am trying for this alternative because here we have 2 hours of supply from the utility followed by 4 hours of power cuts in desperate summers.
