Testing Charge Controller
  • 66ChevellePost
    • Jun 2009
    • 8
    Hi All,
    I bought a charge controller. Can anyone tell me if I can use a wall wart(12vdc of course and within the amp range)to test the controller. Can I connect the output leads of the wall wart into where the solar panel wiring would connect into the charge controller? Will I be ok testing this way as long as I don't go over the max amps of the charge controller.
    Thanks,
    Kenny
    Most charge controllers want to see about 16-25V on the input, and for battery safety, they don't power up unless 9-11V is present at the battery terminal.
    As long as you dont exceed the charge controllers input voltage, or amps, you should be fine.
    • moonrathna
      • Jun 2011
      • 7
      Charge Controller Query
      Mr.Mike,
      I have question to ask.. Can you help me to test the charge controller whether it float and boost voltage working properly??
      I connected Vm 18W panel with 10A CC, 12V battery. I found PV voltage 12.5 and Out of CC to battery also same. But specification of CC reads boost voltage 14.4.
      How to confirm this whether my charge controller is working properly...
      Regards,
      Ratna
        To test a charge controller, will be harder in your case, because you have a small solar panel.
        You will need a volt meter, possibly several sunny hours to do this.
        in the following order, connect things
        Battery to Charge Controller. It should indicate that it is on now.
        measure the battery voltage and write it down.
        Place the PV panel in the sun, measure it's voltage - should be about 19V
        Connect the PV panel to the controllers PV input.
        Measure the battery voltage now, and every 10 minutes, you should see it rising as the PV charges it.
        You cannot apply any loads, or run anything while this test is running.
        If the PV does not have 19V when you first measure it, something is wrong with it
        If the battery does not slowly rise from being charged, either the battery is bad, or the controller is bad.
        • moonrathna
          • Jun 2011
          • 7
          I did the test Mr.Mike,
          But the charge controller should produce the charging voltage 14.1V as per their catalogue isnt it?
          But If I measure the terminal out of charge controller to battery the maximum voltage show up is 13.2V, What does it mean, whether am having problem with charge controller or battery or PV.
          Note: My PV producing 21V Voc and Vm - 16V, Please advice.
          We are using Steca CC, Rocket Battery and Sharp Panel
          Regards,
          Ratna
            When the battery is low, the charge controller will pour power into it, till it comes up to the full voltage. But you have a 100ah battery, and while it's charging, you cannot read the "full" voltage, the weak battery holds the voltage low, till it is charged, then the voltage rises.
              Originally posted by lightsplease
              How fast will the full voltage feature pop up with the spam link deleted ]?
              Very fast, as fast as I can delete 1 spammer and all his posts.
