Question concerning batteries. I presently have a 115 AH battery hooked up and I understand I need a smaller one. What would happen if I hook up a 50 AH battery in parallel with the present 115 AH battery. This is if I leave the panels as they are or if I add panels. Do the batteries have to match?
Most Popular Topics
Small home solar system question.
Originally posted by rgswaim View PostQuestion concerning batteries. I presently have a 115 AH battery hooked up and I understand I need a smaller one. What would happen if I hook up a 50 AH battery in parallel with the present 115 AH battery. This is if I leave the panels as they are or if I add panels. Do the batteries have to match?
What is your use case (on or off-grid, etc.) What size and number of panels do you have?SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
Originally posted by Sunking View PostTo run a 1000/watt battery inverter effectively without tripping off line from under voltage requires a 12 volt 500 AH battery. A 12 volt 500 AH battery requires a minimum 500 watt panel.Comment
