Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 33
Thread: Small home solar system question.
    Jul 2012
    19
    Default Small home solar system question.
    I bought one of the Harbor Freight solar systems a couple of months ago. I want to test out a small system to see if I want to invest further in solar. I have the kit and a 1,000/2,000 watt inverter. My question: What are the best batteries I can use and how many?
    8,380
    Welcome. Sorry for your loss, the HF panel kits are worth nearly nothing, but they do work great as a science project !
    a) 1, 45w kit is undersized for even 1, cheap-o deep cycle battery. So the battery is guaranteed to not be properly charged, and will fail in a couple years. But, good enough for a science project.
    b) you could run a 300W inverter for an hour, maybe two, before you get into deficit charging, depending on the size of the load on the inverter.
    Montgomery Burns
    gear :
    15,986
    To run a 1000/watt battery inverter effectively without tripping off line from under voltage requires a 12 volt 500 AH battery. A 12 volt 500 AH battery requires a minimum 500 watt panel.
    Jul 2012
    19
    So are you saying I need a 45 amp hour battery? Like I said I want to experiment to see if I want to make fuerther investments in solar power. I have seen the youtube videos showing the same 45 watt panels charging two deep cycle batteries. But, they do not tell how long they last or how long the batteries hold up. I am giving thought to buying 2 deep cycle acid batteries from CostCo to further the experiment.
    15,986
    I do not know if the HF panels can even keep up a 50 AH battery. A 50 AH battery can only support about a 100 watt inverter.
    May 2012
    133
    A 1000 watt inverter at full load will drain 100 amps from a 12v battery bank..
    Most inverters are 80-90% effiecent and there is a NO LOAD draw usually on most inverters that tell you how much they will use with no load being on.
    Hence a 300 watt inverter will last about 3 hours.. the issue is if voltage drops below say 12.06 volts (about 50% of DOD).. the battery will not last long..
    Now if your just running a few 13w CFL bulbs and such for testing you should be fine..
    Get a Killawatt meter from HD or Lowes or Amazon for $28 and test for wattage of the items you intend to run.
    This will give you an idea of what you can run safely without ruining the battery prematurely.
    Also running items with the SUN out and on the panels will reduce the draw coming from the batteries..
    Figure a 45 w kit will get you at best case about 20-25 watts getting to the battery..
    Hope this info helps some..
    1160 watts, Midnite 150 , Xantrex SW2000
    Jul 2012
    Southern California
    1,019
    With no real application in mind, and since it is just for experimenting, think SMALL at first.
    Nearly all vids I see with the HF freight panels are running in a "deficit-charge" scenario - too much battery / too big inverter etc.
    I think maybe the first application might be to just size the battery so it isn't too big. I think a 35ah battery or less would be reasonable. And maybe a 120 watt inverter like a pure-sine-wave Samlex PST-12S 12V might be nice. Try to run things off DC if you can, and use the inverter only when necessary. Charge up your phones, and other small items. Charge up AA batteries. Run some simple led lighting. Maybe grab a digital multimeter. Perhaps even get a " P3 kill-a-watt" meter to start measuring the AC power stuff so you can plan for any bigger upgrades down the road.
    The reason for the smaller battery at 35ah or so, is that you don't want to use more than 50 percent of it's capacity at any one time. So that leaves you with 17ah to use and recharge in a reasonable amount of time with those panels. It all depends on your location and solar insolation hours, but I'm going with a generic 10am to 2pm common solar insolation hours availability. It might take more than one day to fully recharge. And of course, how long the battery lasts all depends on how much power your devices draw.
    If you develop a taste for solar, the first thing I'd upgrade is the charge controller. I think the Morningstar Sunguard 4.5a unit is nice enough for a very first upgrade for that kit as a start. The charge controller that comes with the kit is a simple on/off type, which isn't real efficient, and not nice to batteries in the long run.
    If you are like me, the HF stuff turned out to be more of a "proof of concept" and imagination starter, and then the upgrades began after reading the great threads on the board here. I'm still trying to get it right, but that's the fun part of it.
    Jul 2012
    2
    Mike nice post thanks man.
  9. #9
    Jun 2012
    Holiday, FL
    116
    Quote Originally Posted by PNjunction View Post
    The reason for the smaller battery at 35ah or so, is that you don't want to use more than 50 percent of it's capacity at any one time. So that leaves you with 17ah to use and recharge in a reasonable amount of time with those panels. It all depends on your location and solar insolation hours, but I'm going with a generic 10pm to 2pm common solar insolation hours availability. It might take more than one day to fully recharge. And of course, how long the battery lasts all depends on how much power your devices draw.
    I think the HF kits are an excellent starter kit. For a little over 200 dollars(kit and cheap abttery) you can start collecting and using solar energy. What these kit will teach and have taught me most of all is lesson's in production,useage and capacity.
  10. #10
    Jul 2012
    19
    Exactly. Thanks for the response.
