Alternative to Ground Mount Fence?
  • NorthwestPV
    • Jun 2012
    • 14
    I've been trying to find an alternative to installing an ugly chain link fence around our ground mount installs. I looked at the UniSolar product but it doesn't quite work for what we need. I found a plastic product that is intended for poultry fencing that might work. it comes as 3' wide by 25' long. We usually mount our ground mounts in a landscape orientation. If we install all the cables end to end we could run this material up that section on the bottom of rails, then route the cabling between the sections at the top of the array where it will be out of the accessible range. The material is sunlight resistant as well and comes in black or green. What are everyone's thoughts on this?
    I think we need a sketch of how you intend to install it, because your post is not clear at all to me.
      The need for a fence is to keep the area isolated and prevent unauthorized personnel out of the area. A plastic 3 feet high fence is not going to keep anyone out especially children.
      • NorthwestPV
        • Jun 2012
        • 14
        The fencing material is to be mounted under the pv modules to cover the wiring. To create a barrier. The intent is not to have a fence around the array.
          Where I live and per NEC that is not compliant. Wiring would need to be enclosed in a Raceway.
          • NorthwestPV
            • Jun 2012
            • 14
            I created this pdf to illustrate what I intend. The holes in the fencing would be much smaller. If its not readily accessible, it doesn't need to be in a raceway. The wiring along the top would be above the 6'-6" mark.
              that appears to be Snap n rack
              The channels can be used as a raceway and they make a cover for it.
              Put all the wires in the raceway closest to the junction boxes and use the cover. exit above the 8' mark if possible.
              • eds
                Alternative to fencing
                Just a friendly post, in order to download attachments. I'm having the same problem in trying to keep the electrical inspector happy for a ground mounted system without having to fence it in.
                • Rbh110
                  • Aug 2012
                  • 5
                  One solution I haxe seen..
                  Is similar to what you were suggesting.
                  A local company uses plastic (vinyl/polymer) lattice fencing -the one with the smallest openings, maybe a bit over 1 inch. The material is a little under 1/4" thick and comes in 4x8' sheets. They simply screw the fencing to the back of the rails with ss screws and washers to help secure and cover the wires/prevent access.
                  This has passed inspection in a few towns in MA, and MA is big on rules and regulations...
                  Ymmv.
                  • Modelmaker
                    • Aug 2012
                    • 3
                    In the past, in certain areas, we have been able to get away with simply attaching chicken wire to the back of the array to keep things inaccessible, unsightly...Yes, however it is fairly inexpensive.
                    • cvinal007
                      • Sep 2012
                      Alternative for Fencing
                      Just another friendly post, in order to download attachments. I'm having the same problem, for I have clients who would very much like to have a ground mount system, but do not want the ugly chain link fence around the array.
                      • mapmaker
                        • Aug 2012
                        • 353
                        One alternative is to have the panels 8 ft off the ground. That is considered inaccessible. Probably easiest to do with a pole mount.
                        ....mapmaker
                        • green
                          • Aug 2012
                          • 421
                          Here's a question...
                          If the yard is completely fenced in do you still need a fence around a ground mounted array? I'm assuming yes.
                          • jonson07
                            • 6
                            Hi dear today i read this topic it's really nice and informative i would like to share with you something which is that I have an in-ground pool with a square concrete pad around it. I want to get a black aluminum fence around it, and mount it ONTO the concrete at the edge. Is it OK to do this??
                            Good old fashioned family Service
                            • Szumlanski
                              • Dec 2011
                              • 15
                              Florida Glass
                              Some AHJs done require a fence around the array. In Southwest Florida, in some jurisdictions, a product called "Florida Glass" can be used to either surround the back of the array or to cover the back of the panels. Florida glass is just vinyl laminated fiberglass screen material. It is very tough, and used for privacy on screened enclosures or along the bottom of enclosures where mowers often tear regular screens with blown debris. If that is not acceptable, chicken wire, hog wire, welded wire, or chain link are common steel materials used. Heavy hedges can be used for aesthetic purposes, but this undoubtedly will not pass for protection purposes if your building department requires it.
                              Jason Szumlanski
