Technical information on Solar Panels?
  • Jeff_the_electrician
    • Dec 2008
    • 8
    When load is switched on to solar panels, does it's terminal voltage fall? To put it another way, how susceptible to internal voltage-drop are the solar panels?
    Thanks,
    Jeff
  • Jason
    Administrator
    • Dec 2008
    • 990
    Hi Jeff,
    The are very susceptible. They have a relatively high internal resistance, and it varies with the amount of sunlight.
    • solar_geoff
      • Jan 2009
      • 49
      With regard to voltage drop in PV design, voltage drop needs be be considered both on the DC and the AC side, with AC voltage drop being much more critical. I am not sure that I have ever considered the voltage drop within the modules themselves, as I would consider them to be the voltage source on the DC side. I would consider any design consideration for the internal voltage drop to be the responsiblity of the manufacturer.
      For DC runs longer than about 50-60 feet we will check the voltage drop and try to limit to 1-1.5%. This is not critical to the operation of the system, however it ensures efficient operation. Usually remedying a DC voltage drop higher than 1.5% only takes bumping the wire size from 10awg to 8awg at most.
      On the AC side, the voltage drop is extremely important. The NEC limits voltage drop to 3%, however for efficient operation of the inverter, the voltage drop from inverter to main service panel should be no more than 1-1.5%. SMA recommends no more than 1%. If the voltage drop is too high the AC voltage seen by the inverter will higher than the nominal utilty voltage and potentially outside of the inverter's operating range.
        • Dec 2008
        • 8
        i'm a little late on replying but I just wanted to say thanks guys. Solar_GEoff your answre was helpful thanks man
        • MarineLiner
          Solar Skipper
          • 656
          Originally posted by solar_geoff
          ...voltage drop in PV design, ... needs be be considered both on the DC and the AC side, with AC voltage drop being much more critical. ...
          remedying a DC voltage drop higher than 1.5% only takes bumping the wire size from 10awg to 8awg at most. ...
          On the AC side, the voltage drop is extremely important. The NEC limits voltage drop to 3%, ...
          • Off Grid Solar
            • Jun 2009
            • 125
            Jeff, If the DC voltage draw is greater than the solar panel's combined voltage the voltage will fall. If the device draws 12 volts and the solar panel puts out 41 volts the voltage should not fall at all.
            • Off Grid Solar
              • Jun 2009
              • 125
              He is right.
                panels do sag, according to load. The specs:
                Max Power Voltage - Vmp
                Open Circuit Voltage - Voc
                tell you the max, and the best voltage points to allow for. That's why MPPT charge controllers work, by playing with the load on the PV, and downconverting the output voltage.
                • MarineLiner
                  Solar Skipper
                  • 656
                  Charge controller managing ...
                  Right. Though, i prefer to say Charge controller managing in other word of controlling. But playing also can handle.
                  In extrim case burn can happen?
