If I have a 12v deep cycle marine battery and I connect a couple water pumps directly to this battery, is that all that I need to do? Or, is there more to this? Does the correct about of current flow to the water pump based on the type of pump? Or, do I run the risk of burning up my water pumps if I don't do something more?
Basic Question about 12v battery and dc water pump
you need more than just the battery and pump. you need a fuse between the pump and the battery. the fuse is sized according to the wire and the pump. you should also have a switch. i suggest you have a volt meter also, so you can have some idea of how much energy is left in the battery. how do you plan to recharge it? If you just let the water pump continuously, it will drain the battery pretty fast, depending on the pump and the size of the battery. good luck
Mod note - Removed linkLast edited by russ; 05-12-2012, 07:40 AM.Driver of the Solar Bus -
solar controller
OK, so if I charge the battery with a solar panel via a solar controller and I put a switch between the water pump(s) and the solar controller, then these problems should go away? What kind of fancy switches do they have out there? Are there some with a photosensor that turn off at night and on during the day and vice versa? Are there other's are timer based that just run from say noon to 4 pm?
I guess my question was what prevents all the juice from the battery going into the water pumps all at once and ruining the pump? Is the pump designed to only draw a certain amount of power? Is that amount of power determined by the voltage of the battery? If I were to use a 24 volt battery, would twice as much water come out? Sorry, but I still have a little bit to learn about the basics.
Originally posted by garybeck View Postyou need more than just the battery and pump.
good luckComment
Fuse?
For motor or other larger loads, I prefer fusible links to fuses. They have
less voltage loss, and avoid contact corrosion problems, which could be bad
around water. Easily available from automotive sources, 12 to 20 gauge.
Bruce RoeComment
Originally posted by natel View PostI guess my question was what prevents all the juice from the battery going into the water pumps all at once and ruining the pump?
Originally posted by natel View PostIs the pump designed to only draw a certain amount of power?
Originally posted by natel View PostIs that amount of power determined by the voltage of the battery?
Originally posted by natel View PostIf I were to use a 24 volt battery, would twice as much water come out?MSEE, PEComment
Rogue makes a low voltage cut off that is fused. They are adjustable as to the voltage they will turn off the load. When I have used these I limit the turn off voltage to about a 50% DOD.
They run about $35 and will save your battery(s)NABCEP certified Technical Sales Professional
to elaborate,,,, a pump uses a certain amount of amperage (amps). it will say how many amps somewhere on the package. that is how much power it will draw from the battery. it won't drain it all at once. the wire should be sized according to that amperage. every wire has a maximum amperage. make sure your wire is at least as big as the amperage of the motor.Driver of the Solar BusComment
