Fleabay Stackable inverters
  • Filter
  • Fleabay Stackable inverters
    I've been looking at the stackable inverters on ebay, does anyone have any experience with them? I've searched high and low, and can not find a good or bad review of them. They would really serve me well if they are good products, and they can grow with a growing system...
    http://www.ebay.com/itm/NEW-Stackabl...item43ab104744
    That is just one that I pulled up for this post... they come in all shapes and sizes, from 12v to 48v input. There is even a 240v 60hz one... is that true 240? two 120's and a neutral? Does not show the info on the diagram that is on the page. Again, I was just seeing if anyone had any info on them.
    Thanks.
  • #2
    The syntax in that add reeks of Chinese
    USA seller NOT.
    • #3
      1) links to ebay are generally a bad idea, because in 6 months, they are broken, and don't work.
      2)
      NEW Stackable 2500W Power Inverter 24V DC to 110V AC WATT 5000W
      You can only get 110V out, no 240 without a transformer.
      Output Wave Form: Modified Sine Wave - won't work with a transformer
      and at the bottom of the listing :
      Units stack on the AC side in parallel ONLY but NOT in series.
      120 + 120 in series will NOT work out to be 240 volts output!
      and I really hate inverters with 2 parallel input terminals, as they rarely provide proper internal wiring.
      90% efficient, 2500w will pull about 120 Amps from your 24V battery. 2 wires would need a pair of #4 wires, trying to get 4, #4 wires onto that, will be a mess. (two + and two - )
      The higher wattage inverter, you need higher voltage battery system.
      • #4
        Originally posted by Mike90250 View Post
        1)
        I knew two 120s wont give me 240, but the advertised 240v models, I wonder if they have two 120 outs and a neutral, or is it 240 on one wire, which I dont know what in the world that could be used for.
