Solar Powered Radio
  • Solar Powered Radio
    Im trying to rig up a solar powered radio. The info on my radio is 120V 60Hz and 65 Watts. I have a small motorcycle battery I was hoping to use.
    Is it as easy as connecting my radio and the solar panel to the battery?
    What size/rating of a panel will I need? Is there other equipment/hardware I will need?
    I really appreciate any and all help you guys can provide!!
    you will need the following
    A small solar panel probably without calculating in the 60W range depending on how long you want to run the radio.
    A charge controller to regulate battery charging. 5A PWM should do it
    An inverter Preferrably a pure sine wave with a rated capacity of 100W
    A slightly larger battery somewhere in the 50H range preferrably at least a deep cycle
    So to add all that up
    60W panel $ 200.00
    Charge controller $45.00
    Inverter $ 100.00
    Battery $75.00
    Total $ 420.00
      I do not think the radio in question uses 65 watts. It might tif it is a 50 year old tube radio.
      No modern radio consumes more that 5 watts in receive mode, and will not even come close to 65 watts average if it has a transmitter.
