project of mine: 12v panel to charge 8 aa batteries
  • #16
    Originally posted by noone View Post
    In this case....it IS however wrong to say that self regulating solar panels do not exist.
    They DO
    You are 100% correct. Every solar panel is self regulating because they are current sources a point which I do no think you have grasped yet. A typical 100 watt panel made for 12 volt battery systems has a Voc of 22 volts and a Isc of 7 amps.
    Shell made that panel in the link above and refer to that as self regulating (and it was designed for battery charging....not just trickle charging). That is a 50 watt panel model SM50-H and it typically puts out 14.5 volts.
    Kyocera make self regulating panels (model Kc35 is a 15 volt 35 watt panel.)
    OK this is where you stepped into a big pile of it and where I think you do not understand what a current source is. The Shell panel you mention for example is a 50 watt panel made with 33 cells. It specifically says to be used on a 12 Volt 100 AH battery with a daily load. Please read it and explain why it is so specific
    Here is your clue. A 50 watt panel with 33 cells can only generate 3 amps of current. When applied to a 100 AH battery is a C/33 charge current. If you connected that panel to a 50% discharged battery it would take roughly 5 days to fully recharge the battery assuming the battery had no load on it. That by definition as I explained earlier is a TRICKLE CHARGER. To properly charge that same 12 volt 100 AH battery would require a 160 watt panel with a MPPT charge controller, or a 220 watt panel with a PWM charge controller. To recharge that same battery at 50% would only require 1 day with a light load, not 5 painful days without a load.
    Some self regulating panels are sold with a 12 volt cigarette plug to plug 12 volt things in directly to the panel (like my 5 watt panel which as I said, came with both a 12 volt cigarette plug and a set of alligator clips).
    Again that is not a self regulating panel. It is just an over priced Marketing Term for a piece of junk. a 5 watt, 12 volt panel generates .3 amps. Car batteries are anywhere from 60 to 100 AH. So a .3 amp current supply is a C/200 to C/333 charge rate. There is no way in Hell that could even possible charge a car battery. A Trickle Charge is around C/100. So that 5 watt panel is not even a TINKLE CHARGER. A 50% discharged 60 AH battery would take roughly 1 month to charge up assuming the battery does not have a self discharge rate. A flooded lead acid battery has a 10%/Month Self Discharge rate. The 5 watt panel can barely keep up with the Self Discharge rate of a 60 AH battery. It is a worthless piece of crap only worth $5. How much did you pay for it?
    • #17
      I disagree on that Shell panel being a trickle charger...ok it is not going to do much more than that with that 100Ah battery (and yes I did read it and I KNOW they are very specific for a reason, I am not advocating using THAT panel for anything...period, it was just a link to prove the point on the terminology...if some one wants THAT panel, then follow the instructions for THAT).
      Shell calls it a self regulating panel (and also refrers to trickle chargers as well), so that is good enough for me.
      I would not use my 5 watt panel to charge ANY battery, not even a small AGM (I use other panels for that), for charging AA batteries though, it has been invaluable to me and in fact I consider it to be the best value thing I have EVER purchased ...and I did pay a LOT more ten years ago for it that I would today.
      It is not like I am going to charge AA batteries with my 50 watt or 200 watt or what have you panels and like wise will not charge larger batteries with my 5 watt one.
      Again and finally, it is just a name.....I actually think calling a panel "self regulating" as a term is a bit misleading but that IS what such panels are called.
      I think I am done on this, there ARE self regulating panels, a 5 watt panel is great for charging AA batteries (not a 200000AH AGM battery) but ONLY if you are using a lower input to what you otherwise would and ONLY if you know what you are doing and at your own risk.
      • #18
        Trouble ediiting
        Hi
        I had trouble editing so just post again.
        The definition of a trickle charger
        That Shell panel does a bit more than this.
        http://en.wikipedia.org/wiki/Trickle_charging
        The end for me on this.
        • #19
          It is called Marketing to Dummies 101.
          • #20
            Or maybe 'green washing 101'.
            Some idiot in their office wrote that and probably had zero idea what they were writing about.
            • #21
              They are no idiot, very clever Marketers. They come from the same school PT Barnum came from.
