Hello,
I would like to boost my Solar Sign lights by adding an additional battery so they stay on longer. Right now they use a single solar panel 12" x 7", charging a 6V 4aH battery, i have attached pics of everything. I have added 50 feet of 24awg, 300v, wire to extend the panels to the rear of the building for optimal sun exposure, this was negligible to the system. I would like to add a 6V 10aH battery to triple the on time for the lights by wiring the new battery parallel to the existing one.
Can i do this and achieve more on time for the lights or will i need to upgrade the solar panel as well. I do not want to change the wire as i had to solder & splice the 50 foot extension. The lights are 54 LED which work quite well for the 5-7 hours they stay on however on cloudy days sometimes they don't even come on. I replaced the batteries so they are new. Ignore the motion sensor as the pics are my parts unit, the motion detector is removed from the circuit in the setup i am now running.
This is what i came up with to boost the system but if there is an easier way please suggest. I do not want to buy new lights and want to use the existing led array and solar controller that comes with the unit. see pics. I am in Upstate NY for sun exposure. I am also quite technical so if someone wants to mod the existing controller or send me pcb drawings i am OK with that.
Thanks for the Help,
Robert
http://i1216.photobucket.com/albums/...h/DSC06417.jpg
http://i1216.photobucket.com/albums/...h/DSC06418.jpg
http://i1216.photobucket.com/albums/...h/DSC06421.jpg
http://i1216.photobucket.com/albums/...h/DSC06422.jpg
http://i1216.photobucket.com/albums/...h/DSC06423.jpg
http://i1216.photobucket.com/albums/...h/DSC06424.jpg
http://i1216.photobucket.com/albums/...h/DSC06425.jpg
Robert
