I am pulling up roots and heading west and have some questions about how to power my c-pap machine all/every night and recharge all day. How do I determine wattage needed and what type of equipment do I need. It can operate in DC mode if that will help. thanks
Most Popular Content
new solar user
hi and welcome
Someone here has that exact same problem and will be along to help.NABCEP certified Technical Sales Professional
here's a thread about CPAP
http://www.solarpaneltalk.com/showth...highlight=cpap
What I do for 1 overnight, is I have a automotive battery jumper pack, that has a 12V outlet, and 2x the watt hour capacity I need for 1 night.
I have a couple posts in that thread that cover what I did
MikePowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
overnight
I am also considering running a fan with the c-pap machine. How do I calculate the wattage of solar panels. If that is an equipment list I'd appreciate it written in a more understandable format as I rode the little bus.
thank you, PaulComment
Originally posted by pzed View PostI am also considering running a fan with the c-pap machine. How do I calculate the wattage of solar panels. If that is an equipment list I'd appreciate it written in a more understandable format as I rode the little bus. thank you, Paul
Write down the Watt Hours Divide by 7 = WH needed for 1 day.
Give us that daily number, and then we can calculate the battery and inverter needed.
Unless storms take out your power on sunny days, PV won't help a lot, a regular battery charger is better.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
PV
Explain PV. Also, where would I get a killawatt meter and are they expensive? Also isn't DC power created by solar panels? Why would I need an inverter - my c-pap is AC or DC with a different cord and I believe I can purchase a DC powered fan?
thanksComment
Originally posted by pzed View PostExplain PV. Also, where would I get a killawatt meter and are they expensive?
A Killawatt can be found on line or at any big box store I expect - I just saw 16$ on the net[SIGPIC][/SIGPIC]Comment
another question please
Originally posted by pzed View PostExplain PV. Also, where would I get a killawatt meter and are they expensive? Also isn't DC power created by solar panels? Why would I need an inverter - my c-pap is AC or DC with a different cord and I believe I can purchase a DC powered fan?
thanksComment
thanks
Kill-a-watt meter
http://www.amazon.com/P3-Internation.../dp/B00009MDBU
You will have to research for yourself, if you obtain better efficiency, or better performance, with a DC or AC fan. YOU need to measure the draw both ways, and decide what You want.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
