  • Filter
  • emJayOwen
    • Mar 2012
    Newbie with a question!
    Hi all!
    I've currently got a 2.4kW PV system installed on my property in the UK. I'm trying to work out how many kWh/year it'll generate but am struggling with the equations I've read.
    From the SAP 2005 calculations, it states the generation = 0.75 x kW(peak) x S x Zpv
    where S is the irradiance and Zpv is the overshading factor, being 1126 and 1 respectively.
    The problem I'm having is where does the solar panel efficiency come in to the equation? My panels are rated at <16% according to the specification sheets.
    Sorry for the question, any help would be greatly appreciated.
    Thanks!
    Thanks!
    The panel efficiency is already accounted for in the kW(peak)
      I would just use PV watts http://www.nrel.gov/rredc/pvwatts/ which uses 20 years of weather data, and you just enter your panel / array info.
