Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 46
Thread: How do you solder 6X6, three tabbed cells @ the end ?
  1. #11
    Mar 2011
    Philippines 10%
    238
    It is rated at 0.5 volts,around o.55 open circuit voltage. Even without tab wires, you should be able to measure the voltage. Poke tester leads directly where the tab should go(red on the bottom, black on top) You dont have to connect all the tabs to get a reading. One on top and one on bottom is enough.
  2. #12
    8,217
    Quote Originally Posted by _madtrapper View Post
    Right now I cannot even manage to get one cell to pump out the proper Voltage (4.1v) !! ...
    Regardless of size, a single wafer/cell will only produce 0.5V That's why it takes 36 of them in series to have enough voltage to recharge a 12V battery.
    Amps depend on the amount of (intensity) light shining on them.
    What sort of spec sheet acompanied the cells ?
  3. #13
    Oct 2010
    738
    Madtrappers problem seems to start from what appears to be tha fact.NO information came with the cells.
    Flea Bay specials?? 3rd rate,and way below spec.?
    The usual type of cell DIYs use to make substandard ,short lived panels.
  4. #14
    May 2011
    Pennsylvania
    40
    Default 3 Tabbed cells
    I can see why the third tab is baffling you but it is buss tabbed the same as single or double tabbed cells. The front of the cell is negative and the back is positive. Connect your cells to the string size you need pos to neg for each cell. To connect 2 strings to a buss tab solder all 3 tab wires of the neg to the buss then connect all 3 pos tab wires in the next string to the buss. Heres a diagram I made. See if it makes sense now. Good luck
  5. #15
    May 2011
    Pennsylvania
    40
    Sorry madtrapper I see you only want to connect 2 cells. Tab first cell on front side for neg.and leave extra at top to connect to a buss tab. Tab the secnd cell on back pos side and leave extra tabing to connect to a bus tab . tab all three to the bus tab at neg and pos. Those are your plus and minus connections
  6. #16
    Dec 2011
    Philippines
    4
    that's the same cell i want to import last i check china sources cause it's new product line.
    4w 6x6 mono, i think it's around 5$ a piece....
    my supplier told me last time it's no different from the 2tab connection
  7. #17
    Jan 2012
    15
    Default Buying cells
    I managed to get these cells @ $1 A Cell from a local panel maker(in the box). The are rated 4.1v. Tabbing all three of the (+) together & all three of the (-) together is only giving me .5v. Understood it's going to be less indoors but NOT over three volts worth !!
    Quote Originally Posted by Panjong View Post
  8. #18
    Mar 2011
    Philippines 10%
    238
    You are never going to get 4.1 volts on a single cell whether indoor or outdoor. You could get 0.6v open circuit in full sun if you are lucky. Voltage wouldn't change much in different sunlight conditions. It's the current that's changing. There must be a typing error, you are seeing maybe 4._ watts(0.5v, 8a) per cell. You need to do a lot of research and reading to be able to make a solar panel.
  9. #19
    Feb 2011
    Annapolis Md
    6,238
    I think they are quoting or referring to VA or watts not voltage.
    Rich
    WWW.solarsaves.net
    www.gaisma.com
  10. #20
    Jan 2012
    15
    Part of the problem I have figuring things out is that each cell has a + & -. Ergo 2+ & 2 -. When you attach the top to the bottom of the next you have more + than -.
    OK. IF you go from the bottom of the 1st cell to the top of the second cell, what/how do you connect the top (-) of 1st to the bottom(+) of 2nd cell?
    WHAT'S wrong with my diagram (crude but should get the point across).
    What's wrong in the attachment ??
    Thanks in advance guy(s) for yer help.
    (I HATE BRAIN FARTS !!!!)
    P.S.
    Axis; the voltage was hand written, which makes me think that, what I was told was correct.
    Quote Originally Posted by axis11 View Post
