Mike,
Have you read your Nickel Iron Battery Warranty closely?
Appendix B
15 Year Limited Warranty
BeUtilityFree, Inc warrants both the cells against material and workmanship and battery
capacity.
Material and workmanship warranty:
BeUtilityFree™, Inc. warrants to the original user and is non-transferable and that all
new nickel iron pocket plate cells models will be free from defects in material and or
workmanship (not just being discharged) within the replacement period stated will be
replaced free of charge. for (15) fifteen years (180 months) after placed in service. User
should immediately report any possible defects in writing to BeUtilityFree™, Inc.
Battery capacity warranty:
We warranty the battery to produce a minimum of 80% of its rated battery capacity at a
C20 rate for the first 10 years in service as tested by industry battery testing methods.
Warranty Period Workmanship
Free replacement: 1st 60 months
Pro-rated: 120 months after the 1st 60 months
Warranty inclusions and exclusions
All batteries claimed to be defective must be returned to BeUtilityFree™, or the closest
dealer for evaluation.
During the first year from date of shipment delivery to customers
address we will pay for return shipping, but not shipping to BUF, if cell(s) are found to be
defective.
After first year, customer pays all shipping expenses both ways.
Allow up to
2-4 weeks for examination of batteries that are in question if they are returned to us. No
replacement cells will be sent unless bad cells are received first. No exceptions.
If you
need to send all the cells back to us then send the cells back to us in the original wood
crate that the cells came in. or construct replacement boxes of similar construction.
BeUtilityFree is not responsible for installation, removal of cells, labor costs of removal
and replacement, electrical test or any kind, loss of time, loss of equipment use,
recharging and charging cell(s), and another costs related to be considered as incidental
or consequential damages.
The following conditions must be met or guarantee is NULL and VOID:
1. The batteries are used in a home power system or approved system by
BeUtilityFree™, Inc. engineering department.
2. Battery bank should not be installed in an environment that exceeds 100 F° for
extended periods of time, such as a dark box in the sun.
3. The batteries are handled, stored and installed in accordance with the instructions
shipped with the batteries.
Proper maintenance records should be kept regarding
temperatures; specific gravity, cell voltages, and battery carbonate content on a yearly
basis.
4. Electrolyte level must be maintained at the recommended level at all times. Only
distilled or de-ionized water can be used to replace fluid level. Rainwater, city tap
water, well water or seawater will void warranty.
5. Applies only to original owner and does not cover any battery that must be repaired or
replaced due to misuse, accidents, negligence, tampering, or acts of God.
6. Battery terminals and intercell connectors must be tight to assure no arcing occurs
during heavy charging and discharging of battery.
7. If battery is found to be contaminated with carbonate during a claim then the claim will
not be honored.
It is the client’s responsibility to monitor the electrolyte carbon
content.
9. The replacement electrolyte bought from us be used when periodic renewal electrolyte
as necessary.
10. Cells have to be flushed with distilled water or water approved by us.
11) The operator of the battery bank must keep reasonable records of use and
maintenance.
Failure to monitor watering intervals, discharges and full recharges may
void the warranty.
12) All battery systems installed in renewable energy systems or electrical vehicle
systems must have an Ah meter device installed in accordance with the manufacturers
installation instructions.
All battery Ah meters must be “synchronized” periodically to
match the rated battery capacity. No constant voltage controllers are allowed.
13) The battery must be charged on a properly sized charging system capable of
delivering a minimum of 40% of its rated C5 Ah charge rate. The “charging system” is
the total sum of all charging sources.
14) The total 100% depth of discharge of your battery bank do not exceed 1000 times
total to an end voltage of 1.0 VPC. If cells taken below 1.0 VPC then warranty is void.
Limited warranty does not apply due to the following:
1. Fluid level not maintained in cell(s) either by over or under watering.
2. Damage from shipping to or from the original owner.
3. Freezing of cells due to low specific gravity.
4. Damage from fire or explosions or any other acts of god
5. Addition of any other chemical besides chemicals purchased from BeUtilityFree, Inc
or approved supplier by BeUtilityFree.
6. Water that is not either distilled or de-ionized and over 10 PPM of TDS.
7. Over or undersized sized battery bank as well as improperly sized for the intended
application.
8. Damaged cases from temperature extremes.
9. Improper installation.
10. Bad electrical connections such as lose nuts or wires or improper wire sizes for
application.
11. Corroded, rusty or improper hardware.
12. Breakage caused by dropping cell or sharp blows to cell.
13. Insufficient charging by charging source.
14. Tampering with wording or manufacturing codes the cell or tampering with cell itself
in any way.
15. Cracked, broken, or cracked cell cases not caused by manufacturing defect.
16. Freezing of cells due to low specific gravity.
17. Your warranty does not cover cell replacement caused by loss of battery capacity due
to carbonated electrolyte. If we find this to be the case, we give you the option of us
changing electrolyte with new electrolyte and testing them.
18. Only cells sold in North America
19. Float purchased from another company and used in the cells
The registration form is filled out within (30) thirty days of receiving batteries and
sent to:
Attn: Customer Service
You can also scan and email the filled out form in PDF format to
If the warranty paperwork is NOT filled out and sent in than your cells will
not be covered under the warranty terms.
NO EXCEPTIONS!
How to obtain warranty service:
All returns must be followed by a Return Authorization Number (RAN) issued by
BeUtilityFree™, Inc. in writing to the customer service department. Customer is
responsible for costs and proper packaging of cell(s). All cells must be returned to us
before guarantee is honored. Shipping instructions will be sent with the RAN. Proof of
purchase (invoice) must be presented at time filing for an RAN
If defective during the first year we will replace free of charge including labor, freight
and and parts replaced with one of equal amp hour battery capacity and we will endeavor
to replace with the physical size cell. The second through the fifteen years will be
warranted on a pro-rated basis.
BeUtilityFree, Inc
The pro-ration formula is:
Credit = current purchase price ($XXX) X number of months of service ÷ Warranty
period
Because cell dimension can change from year to year we cannot guarantee that the
replacement cell(s) will be the same size as the cell)s) that you originally bought. Usually
the older the cells are more likely the cell could be a different dimension. The amp hour
cell capacity shall be the same as the original or as close as we can get should the cell AH
capacities not be matched exactly.
Packaging requirements
Package must be packaged according to shipper’s standard practices for the weight of the
cell. Please use proper packing material that will not crush under the weight of the cell.
We suggest bubble wrap as the best packing material.
Limitations of Warranty
BeUtilityFree makes no express warranties with respect to its to its cells sold other than
the limited warranty stated in this warranty
Disclaimer of consequential damages
BeUtilityFree, Inc shall not be responsible for any liability caused by incidental or
consequential damages caused by operation of the nickel iron cells, from the sale of this
product or relating to the use of this product.
Application pertaining to State Laws
This warranty gives the original owner specific legal rights and you may also have other
rights that may vary on a state by state basis.
This area intentionally left blank
BeUtilityFree, Inc
There is another version of the same Warranty but it won't copy for some reason.
I will have to try a desktop that is set-up to deal with tricky stuff.
It has additions like items related to your Ah meter.
"If your battery history setting are deleted or reset then warranty is void".
So be careful with your printed records and don't accidentally reset your Ah meter
or your out of the John Mario D'Angelo
Shrine.
If you get some carbonate problems same deal.
Your out of the Shrine.
Charging Less than 40% of C5 ... well I'll let Sunking tell you.
Stephen over at Zapp Works said that they figured out a way to reverse recent
carbonation and he was telling his customers all about it. Then this year they wrote it out
of their instructions. The sly devils. Changhong Batteries (Your Company) is also
'writing some things out' this year. Old Bill won't do you dat way
Based on some things that John Mario said recently (in writing of course) I think
that I figured out what may have happened to your Ni-Fe Cells.
(Next time.)
Bill Blake
Appendix B
capacity.
defective.
Allow up to
If you
basis.
not be honored.
content.
as necessary.
maintenance.
void the warranty.
application.
application.
in any way.
sent to:
NO EXCEPTIONS!
BeUtilityFree, Inc
period
BeUtilityFree, Inc
Shrine.
(Next time.)
Bill Blake
