Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: Installing an analog ammeter
    Dec 2010
    Metro Manila Philippines
    35
    Default Installing an analog ammeter
    Hi,
    Anybody here who knows how to install an analog ammeter to measure the current coming from the panels? I tried doing it by directly wiring the meter in series with the positive wire, it gives me a reading but it trips the controller after a few seconds. I heard from somebody that you ned to put a resistor and a diode so that it won't trip. By any chance anybody here knows if thats a true and if so, can somebody give me the diagram and parts needed?
    Thanks!
    Oct 2010
    738
    You need to buy a shunt (50a) but depends on what the aprox full amps you are likely to ever get from the panles.. its best to get a shunt size tso that your reading will be about half the shunt rating...wire it in series with the positive wire from the panels then connect a millivolt meter across the shunt to read the amps
    14,590
    Are you asking for a permanent meter or test meter?
    Both work the same way if using a shunt type meter. A shunt is a precision power resistor designed to develop 50 milli-volts at full scale reading.
    Feb 2011
    northern nh
    120
    I added a 3' piece of #14 wire between the charge controller and the batteries. This is my shunt resistor. I calibrated it but snipping of bits of wire until it read the same as my 10 AMP multimeter. I think it's something like 0.002 ohms, so the voltage developed across this resister is 0.024 volts. THen you just need to buy or make a meter that will sense this voltage.
    Or you could just buy this for 15 AMP DC ammeter for 8$
    http://www.mpja.com/prodinfo.asp?number=17254+ME
    Dec 2010
    35
    I'm planning to make it a permanent meter to constantly measure the current my panels are giving.
    Dec 2010
    35
    Quote Originally Posted by john p View Post
    I have 4 pcs. 100watt panels @ 12v / 5.7a. Please pardon my ignorance, after I buy a shunt how do i connect my analog ammeter then?
    Thanks!
    Feb 2011
    northern nh
    120
    Quote Originally Posted by raymondalmeda View Post
    Thanks!
    This 30 Amp meter has a built in shunt. Just install it between the charge controller and the battery.
    http://www.mpja.com/prodinfo.asp?number=17679+ME
    Oct 2010
    738
    Raymondalmeda If you use a shunt you use a millivolt meter as shown in the simple drawing to read the amps usually 1a =1mv .if you dont use a shunt you just connect the 30a ampmeter as shown in the drawing where the shunt is. you dont need any diodes or anything else .
  9. #9
    8,014
    you could get an old automotive ammeter with 2 terminal lugs on it, those often have the internal shunt, but only read in 5A increments.
  10. #10
    Oct 2010
    738
    But Mike he may have trouble finding a 1948 Hudson Hornet to get the ampmeter..??
    Mabe it easier if he just goes to an electronics parts shop and either buys a 50a shunt and a millivolt meter or a 30a ampmeter,..
Tags for this Thread
