Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: water heater
    Jan 2011
    22
    Default water heater
    I was wondering if I had a 3800 watt 240 volt hot water heater how many solar panels would I need to power it? I'd have an on off switch and only use it about 3 hours a day. So how many amps and volts on a solar panel would I need to power it for an hour. Also how do I calculate how many amps a 12 volt solar battery will hold?
    16,251
    How many thousand of dollars are you willing to spend? It will take at least high 4 decimal places $$$$, more than likely low 5 $$$$$ unless you live on the Left Southern coast of LA or south of there . Need to know more?
    8,624
    I would look at a solar hot water heater, not electric .
    Collecting solar heat is about 40% efficient, solar electric is about 15%.
    Look at http://solarroofs.com/ for some good DIY sizer and info.
    Jan 2011
    25
    I know you didn't ask this, but these guys look cool. I hope they're successful and the technology plays out! Hot water & electricity generation in the same unit (from what I can tell)
    http://www.pvtsolar.com/
    Jul 2009
    10,366
    I don't like a website that is pretty but has no facts or details on it.
    The most informative statement provided on the entire site is, 'PVT Solar cannot guarantee performance results'.
    The hot water and electrical generation assumptions they make are not supported by anything but salesman talk.
    The graphics page shown is pretty. Until they become more informative I would not bother with them. They do know all the buzz words and catch phrases. They throw in the DOE and the names of it's programs and software - you can also get that stuff off the DOE site.
    Russ
    8,624
    Quote Originally Posted by Stomp View Post
    vapor ware
    Jan 2011
    22
    I saw a water heater that was around 3800 watts, 16 amps, 240 volts. So wouldn't it take a lot less watts to power, like a solar panel that was 24 volts, 15 amps, it would only have to be around 160 watts if I don't use it at night anyway so I'd need no extra.
    Jul 2009
    10,366
    How many liters (gallons) hot water would you plan on using? What is the water temperature before heating and the desired hot water temperature. Those numbers are the basis of all calculations.
    To estimate the consumption the DOE web site has a format http://www.energysavers.gov/your_hom.../mytopic=12990
    If you provide a quantity I will try to assist you.
    Russ
  9. #9
    Mar 2011
    California
    46
    Default Heliatos solar water heater
    I came across this product that looks promising.
    http://www.heliatos.com/
    Ray
  10. #10
    Jul 2009
    10,366
    The problem with Heliatos is that they are very small units 24'' square more or less (600mm square. They seem to be certified by 'Tony, Two Guys and a Truck'. They would not qualify for any rebates certainly.
    If a panel is not listed by the Solar Rating and Certification Corporation http://www.solar-rating.org/
    A good source of information is 1) http://www2.fsec.ucf.edu/en/industry...nual/index.htm
    Russ
