Would the resistive shunt work? What I'd want measure is the available power from the solar panel - not necessarily the actual power drawn through a set resistor, which would be related to the value of the resistive load connected. If I wanted to check the max power available from a solar panel how would you do that? The power that you measure with the resistive shunt suggested would only measure the power drawn - proportional to the resistive connected. Therefore - if you had a smaller resistive load, the solar panel would generate a smaller power output? Does that sound right, or am I missing the point?
Generally, what I want to measure & compare the varying power of 2no. solar panels - with various inclinations & directions etc. Put I wouldn't be able to do this, if the resistive load attached were identical - and power was available from both solar panels regardless of the inclination & direction. I would still only measure the the set power output - relative to the resistor. Does that sound correct anyone?
