PV to water heating
  • #16
    Hi, thanks for the info. I did try Waste Not Hi again but didn't have much luck. I'll give it another go you your settings. The SOC is working well. The cylinder reached 60 deg C after about 5 hours sun and then a couple more the next day. The thermostat interrupts the control voltage to the SSR. My element is 24 volt 900w and the PV array is 1920w so that fits into what you suggested. SOC normally is 99% at about 10am. In winter the hot water will be maintained by the woodburner which is also our oven so I'm very happy with the system.
    Cheers,
