I am going to install a Schneider Conex SW4048 system in an off grid garage I am building. I had the builder put in a grounding wire (tied into the rebar under the slab) on one side of the garage and now it looks like I will be installing my inverter on the opposite side. I plan to install a 240v AC subpanel on the side with the ground. Can I float the neutral in the Scheider AC panel connected to the 4048 inverter and bond the neutral and ground busses in the subpanel? Or is this asking for trouble because the path to ground will be too far away? My ground source will be about a 60 foot wire run from the inverter.
Assuming I can safely do this won't the 240v run to the subpanel provide a path to ground for the inverter AC panel (and everything else that needs to be grounded like the PV panels)?
I am completely off grid and not subject to any inspections but I also want a safe system.
Thanks.
Thanks.
