New Guy With Solar Question...
OP, have you calculated you actual demand? We can't help you design a system that is going to meet your needs until we know what your needs actually are. Buy a "kill-a-watt" meter and log your loads running from it for the period of time you expect to run them in your cabin, once we have that info we can proceed.
Also, read through the sticky section in the off-grid section of this board.1150W, Midnite Classic 200, Cotek PSW, 8 T-605sComment
First, what is OP? Second, I was told I would get like 50 hours from those batteries using my tv and a few lights. Like I said, they are all led lights. The tv is a 32 inch tube. Not sure of the wattage. I bought a 1500/3000 watt inverter thinking in case I needed that much. If I turned all my lights and tv on (estimating my tv in 200 watts) I would only be around 500 watts total. That is what I was told that I would be getting 50 hrs of battery life from. So I figured I'm not going to have the inverter on all weekend. Just from dark to light with some occasional daytime tv. Thats why I bought the panels thinking they would have all week to charge. What if I bought a 1000/2000 watt inverter of maybe a 750/1500 watt inverter and returned the panels and bought the 100 Watt panels instead? I didn't know the inverter used that much power just being on.
Heres what I thought I could do. I wanted to run the tv for an hour or 3 at night, maybe watch a dvd, and have a 14 watt spotlight outside and one or two led lamps inside. Basically powering my whole cabin like I did with my Honda 2000 watt generator without using the gas. I would turn my gen on at dark and run it until the morning just so we had the tv and light. 2-3 gallons of Medium Grade gas a weekend. The cost of what I bought I was told would pay for itself in 6-8 months.
I am planning on buying 12 volt strip lights. You know the ones that come on the roll with the self adhesive. I bought a roll to install some inside lights in my side by side. Super bright. I hooked a 25 ft roll up to a dead quad battery and they ran for 2 weeks straight until the battery finally crapped out. I can run 100 ft inside and 100 ft outside my cabin and light up the whole place. That shouldn't even run them down if all I'm looking for is light right?Comment
First, what is OP? Second, I was told I would get like 50 hours from those batteries using my tv and a few lights. Like I said, they are all led lights. The tv is a 32 inch tube. Not sure of the wattage. I bought a 1500/3000 watt inverter thinking in case I needed that much. If I turned all my lights and tv on (estimating my tv in 200 watts) I would only be around 500 watts total. That is what I was told that I would be getting 50 hrs of battery life from. So I figured I'm not going to have the inverter on all weekend. Just from dark to light with some occasional daytime tv. Thats why I bought the panels thinking they would have all week to charge. What if I bought a 1000/2000 watt inverter of maybe a 750/1500 watt inverter and returned the panels and bought the 100 Watt panels instead? I didn't know the inverter used that much power just being on. Heres what I thought I could do. I wanted to run the tv for an hour or 3 at night, maybe watch a dvd, and have a 14 watt spotlight outside and one or two led lamps inside. Basically powering my whole cabin like I did with my Honda 2000 watt generator without using the gas. I would turn my gen on at dark and run it until the morning just so we had the tv and light. 2-3 gallons of Medium Grade gas a weekend. The cost of what I bought I was told would pay for itself in 6-8 months. I am planning on buying 12 volt strip lights. You know the ones that come on the roll with the self adhesive. I bought a roll to install some inside lights in my side by side. Super bright. I hooked a 25 ft roll up to a dead quad battery and they ran for 2 weeks straight until the battery finally crapped out. I can run 100 ft inside and 100 ft outside my cabin and light up the whole place. That shouldn't even run them down if all I'm looking for is light right?Comment
What if I bought this kit instead?
http://www.ebay.com/itm/Renogy-100W-...item46293fb5d8
for you? Bruce RoeComment
If the battery is an AGM battery then there is a good chance that it can take that high of a charge, but you would need to look at the usage guide published by that manufacturer.
Until you find out, wear gogglesComment
And I wish we could keep on my original post. What you guys are talking about I have no clue of.
Or how about my last comment? Or both. Need help here.
ThanksComment
If these are Flooded Lead Acid batteries, then C/5 is too high. Marine is a generic term that is usually a battery which is designed to perform acceptably for either starting or cycle, but does not excel at either.
You need to sit down and actually calculate your loads, not guess. There is a spreadsheet in the off-grid section where you plug it all in and it spits out a number for you. We need that number in order to help you.
I.E.
TV - 50W x 3hrs = 150W
resting inverter - 5w x 24 hrs = 120w
lights - 50w x 4hrs = 200w
So if the total comes out to .5Kwh per day you then need to find you sun insolation hours for the worst month of the year that the system will be in use. Probably Jan if you're going to use the cabin in Winter, and design the system for that month.1150W, Midnite Classic 200, Cotek PSW, 8 T-605sComment
noticed that the batteries only get warm and start boiling with a voltage at around 15.5v for a 12v battery. massive amp loads dont seem to make them warm because they charge up fast then the amp load drops rapidly so they dont have time to get warm. anyway, would'nt a boat engine dump a big charge on a marine battery to recharge them quickly?
So one cannot assume that "marine" batteries like a massive charge. What kind of batteries do you have and can you find a user guide?Comment
... I was told I would get like 50 hours from those batteries using my tv and a few lights. Like I said, they are all led lights. The tv is a 32 inch tube. Not sure of the wattage. I bought a 1500/3000 watt inverter thinking in case I needed that much. If I turned all my lights and tv on (estimating my tv in 200 watts) I would only be around 500 watts total. That is what I was told that I would be getting 50 hrs of battery life from. So I figured I'm not going to have the inverter on all weekend. Just from dark to light with some occasional daytime tv. Thats why I bought the panels thinking they would have all week to charge. What if I bought a 1000/2000 watt inverter of maybe a 750/1500 watt inverter and returned the panels and bought the 100 Watt panels instead? I didn't know the inverter used that much power just being on.
The only way I could see those batteries lasting 50 hours would be if you only ran 55 watts on them continuously. If you can, I'd definitely return the HF panels and get the Renogy kit instead. At least you'd cut your recharge time by half and give you double the power during the day while you are there.Comment
