Well a 1 hp motor on paper is rated about 750watts. The starting inrush current can be 8 times running current (6000watts) which is high but without a "soft" start it will be more than 3 times (2250watts) the running load.
So again what can the inverter handle in motor starting and how low can the battery voltage dip before the inverter shuts down. Also does the motor only start "once" per day or is it being cycled based on the amount of rock it is crushing.
Have you ever listened to a wood chipper. They run nice and smooth without any wood going through it but gets real load when you stick a big stick in in and will change pitch based on the size of each piece of wood it is working on at any time. Does this rock crusher work the same way or will it start and run at a constant speed no matter what type or how much rock it has to digest?
Again. Too many variables to give a good answer on battery size. Those variables include the amount of sunlight hitting the panels each day and will degradation of the panels reduce the amount needed to start that motor?
