Not that it really matters if you re read what I posted, I did a quick pivot from 202deg to 225deg to achieve a solar production peak at 2 pm. I did describe the 202 degree point but went to 225 for the ease of TOU analysis.
As it works out there are 3 hours between solar peak at 180deg, and so that point is 45 degrees from a 2:00 pm TOU rate transition.
45 degrees = (2+1)hrs*360/24
If I recall 180+45=225 is SW.
Rereading the OP's comments about minimal shading morning or evening, he might be able to go even further to the west. As an example, considering strong afternoon sun to perhaps 6pm and a rate transition at 2; that is a 4 hr spread, splitting the difference would have a desired solar production peak at 4pm to grab the most of the peak TOU.
75 degrees = (4+1) hours*360/24
180+75=255 degrees. That is along ways from 158 deg (97 degrees).
All that would need vetting with something like PV watts, and 255 may be too far, but it sure seems like from a TOU perspective 158 is close to 90 degrees out. Is it serendipity that there is another roof already 90 degrees out?
