I've researched my eyes out and have called a few people, but I seem to get a lot of conflicting information.
My system is small and doesn't move. All panels get ample light at the same time and are never shaded. My panels are less than thirty feet from the charge controller and the batteries are less than five feet from it.
This system is for emergency power and charging. Everything thing I have is 12V DC, or well within the ability of running off my small inverter (which is almost never used). I estimate that if I were to hook up everything I could think I'd ever need at the same time, I would use 1.5 Kwh over 24 hours, most of that being a slow constant draw.
The batteries (stats below) I have are wired in parallel staying at 12V. I do not wish to go to 24V.
Right now I have one 300 Watt panel that is doing OK. I recently got a great deal on four 280 watt panels (stats below) and want to hook them up to my system (removing the old panel) and add more batteries to run a DC Fridge and Freezer.
Now for the problem:
Some people are telling me to put the panels in parallel and some are telling me to wire them in series. The parallel-minded people are saying that the panels have enough volts already and this would bring you to a higher amp rating the batteries can definitely handle. Thus charging faster/better.
The series-mined people are saying that with an MPPT controller you always want to wire in series as along as the charge controller (stats below) can handle it. Maxing the Volts out while staying inside the battery's amp charging rate. Thus charging faster/better.
Of course I want to charge as fast as possible and do what is best to prolong the life of the batteries.
Could you please tell me what configuration you would put these panels. Parallel, series, or 2X2 in series and then each pair linked in parallel? Does it even matter? Other than wire sizing, is there an advantage to either setup?
Personally I'm leaning toward all parallel. The Midnite Solar string sizer says that all 4 panels in series would be excessive. Others say it can handle it.
Thank you.
Here is my equipment:
(6) SLR124 VmaxTank Batteries in parallel AGM
Nominal Voltage 12V
20Hr Capacity 125AH
RC (Min) 260
Energy (kWH) 1.7
Charging Current 8A-35A
Charging Voltage 14.4-14.9V
Float Voltage 13.5V-13.8V
(4) STP280S-20/Wew Solar Panels
Max Power 280W
VMP 31.5V
Imp 8.89A
VOC 39.4V
Max System V 1000V
Max Series Fuse 20a
(1) Midnite Classic 200 Lite Charge Controller
Operating Volts In: 200VDC
Max Hyper VOC 200+battery
Battery Charge Volts 12-93
Absolute Curent Output 74a at 12V Battery
Thank you.
Nominal Voltage 12V
20Hr Capacity 125AH
RC (Min) 260
Energy (kWH) 1.7
Max Power 280W
VMP 31.5V
Imp 8.89A
VOC 39.4V
Max System V 1000V
Max Series Fuse 20a
