DIY question
  • DIY question
    ok so i got a solar panels .now I want to make a solar lantern with 12 V DC battery use for WS2812B LED strip
    Any recommendations for charg circuits or other Thoughts?
    Hello Jimmy and welcome to Solar Panel Talk
    We can help you size your solar / battery system but first you need to provide some more info.
    Those LEDs are 18 watts/ meter. So the first question is how long will the strip be and how many hours a day will it run.
    The info also states the input voltage is 5VDC so a 12v battery will not work directly. It also mentions a "controller" but not the input voltage it takes or the wattage it is rated for.
    You also mentioned having a solar panel. What type and model is it?
    Without more info it would be a wild guess to size your system components.
