Combining panels and wiring
  • Fishov
    • Jun 2012
    • 15
    Hi Everyone,
    I recently pulled a nearly complete solar system out of my friends cottage and i'm now installing it at my own cabin on Lake of the Woods in Northwest Ontario. Included was Xantrex 2400w inverter, Xantrex 40A charge controller, 8 Trojan L16G Deep cycle Batts and 3 panel racks(12 panels total)... 4 Evergreen EC-115-GL panels and 2 racks of 75W BP275ul panels(4 each)
    I need help with how to combine these 3 racks of panels and how to feed them to the charge controller...this is certainly not my area of expertise. If I rack these on my roof (approx30 feet from the charge controller) i'm guessing ill need a combiner box? what size of wire to use from combiner to charge controller.
    I'm hoping for some input on how to do this effectively...any other thoughts?
    Thanks!
  • Amy@altE
    • 1023
    What model inverter and charge controller (C40?)? Need to know if the inverter is 12V,24V. or 48V. Those are 12V panels, so they need to be wired in series to match the voltage of the inverter.
    Solar Queen
    altE Store
    • Fishov
      • Jun 2012
      • 15
      Thanks for your response Amy...
      The inverter is a Xantrex DR2424
      And the charge controller is A Xantrex C40 ... I believe the same one sells at Alt Store
      There are 8 of the 75w Panels and 4 of the Evergreen 115w panels
      • noviasolar
        • Jun 2015
        • 12
        Originally posted by Fishov
        Hi Everyone,
        Thanks!
        too complicated with what you're doing. Why do not you want to use Grid-Tied Basic Solar Kit for easier ..
        Perhaps suggestion as lacking understanding for Solar combination.
          How are you going to wire those 8 batteries and what will be your battery system voltage?
          Depending on the Imp of those panels a rough calculation indicates a 40amp charge controller might not work for a 24volt battery system with over 1000 watts of panels.
          • Fishov
            • Jun 2012
            • 15
            This system was functioning fine at its previous home. When it was removed i wasn't present so i don't know how the panels were tied together and the cabling was left in the original location so i need to replace it. there are 3 racks of panels with 4 on each... 2 racks of the 75w BP275ul and 1 rack of the Evergreen EC-115-GL. I have to find a way to tie these into the system. I believe the Batts were wired for 24v parallel.
              Because your system is made up of different panels and multiple batteries you have to be real careful to wire them back to what the charge controller can accept and safely charge a parallel wired battery system.
              You can do this by getting the "nameplate" info from each panel, the specifications of that Xantrex charge controller and those Trojan batteries. Once that data is known then a wiring plan can be determined.
              • Amy@altE
                • 1023
                Just because the system was working, doesn't mean it was set up correctly or the best way. The voltages of the 2 types of panels are ok together, but the current difference will definitely cause the 115W panels to operate less than optimally.
                (8) BP275 - 12V panel, 4.75AIsc; wire in 4 parallel strings of 2 in series
                (4) Evergreen EL-115 12V panel, 7.62A Isc; wire in 2 parallel strings of 2 in series
                BP275: 4.75A x 4 strings x 1.25 safety = 23.75A
                EL-115: 7.62 x 2 strings x 1.25 = 19.05A
                Adding the currents together results in over 40A, but the 75W panels are probably pulling down the output of the 115W Evergreens, which is why it has been working. To improve the performance, I strongly recommend you get a second charge controller, and use one on each set of panels.
                Your inverter is a 24V inverter ( DR2424 means 2400W, 24V), so the 6V batteries have to be wired in 2 parallel strings of 4 in series.
                If you don't have a good DC breaker box, I recommend you get the Midnite MNDC175 for breakers before and after the charge controllers and between the batteries and inverter.
                A Midnite PV6 and PV3 can be used to combine the 2 different sections of panels, or a single PV12 could be used for both (separates into 2 halves internally). The BPs need 8A breakers, and the Evergreens need 12A for each string.
                Solar Queen
                altE Store
                • Fishov
                  • Jun 2012
                  • 15
                  Thank you Amy... I appreciate your input. This is excellent information. How about the wiring out of the combiner box? What size will I need?
                  • Amy@altE
                    • 1023
                    You'll need to do some work for that, it's not an easy explanation. I recorded a video of it, you can search on You Tube for "Wiring Your Solar Power System". I'm also creating an online guide, but that's not ready yet. It's up to 30 pages right now, yikes!
                    Solar Queen
                    altE Store
                    • Fishov
                      • Jun 2012
                      • 15
                      Thanks again Amy... I've private messaged you about ordering from The Alt store... Thx steve
