All chargers produce Constant Current, the difference is the voltage set points. In a 3-Stage charger the voltage set points are higher than Float, or an over charge condition to force constant current into the battery longer, thus speeding up recharge time. 3 Stage charging is used for daily cycle applications, and Emergency Stand By systems use Float.
3 Stage is hard on batteries, but it is faster which is desired with daily cycle applications. Float Chargers are the Kinder Gentler chargers used for Emergency Stand By and continuous service like a UPS. All commercial operations like Telecom, Utilities, Broadcast, CATV,Military, Emergency Egress Lighting, and other high priority operations use Float Chargers. They are connected to the chargers and never turned off. Every phone call you make and every data bit you send comes from from a Float Charger. Every police radio call comes from a Float Charger. If power fails, you would never know it because when power fails, the batteries are already online ready to take over.
You can use either one you want. Float charges will cost less money. If you know how chargers work, you can make a Float charger just as fast as a 3-stage charger. Most Float chargers you can set the voltage and/or have an EQ switch. Instead of Floating at 13.6 volts on a 12 volt system, just turn it up to 14.4 and you now essential have a stage charger. It is just manual operation rather than automatic.
What is the difference? 3-stage cost more, puts more stress on the battery from gassing, and are a couple of hours faster. So all I am saying is your application is Daily Cycling, it is Emergency Stand By. You can certainly use 3-Stage, but you do not need it.
