Originally posted by LiFePO4_Only
View Post
The only down side is the expense as you are paying a premium for matched cells, Bottom Balanced, and Assembled in a 12 volt package. You are paying 78-cents per watt hour vs 45 cents buying the cells yourself and doing the work. If you are OK with the convenience of a packaged system, go for it. Jack's is a good small businessman and stands behind his products. It is where DIY EV builders buy their batteries and chargers.
Don't cheap out on a charger. At $8000 worth of batteries last thing you want is to destroy them with a cheap charger. How do you intend to charge them? If from commercial power use a good quality CC/CV PFC charger. Jack has them, not sure about 24 volts.
