already have solar panels and looking for hot water heating ,
Our boiler is a band d boiler and our water tank is quite old sp might need replacing or an immersion element added to it .
I have the option to buy and use a solar iboost /immersun as i understand it and heat hot water using the immersion element, I was also interested on the Solar thermal panels I believe they qualify for the RHI incentive but not sure if they can work in parallel with an iboost /immersun?
I guess I can use the Solar photovoltaic and the iboost to convert that electricity to heat, but is it more efficient to use solar thermal panels? How much difference in cost/ efficiency is there?
also your opinion
Shall I add Immersion element on the existing boiler??
System Boiler and water tank replacement (also type of boiler i believe that the same type needs to be used but a more efficient one, because most combi boilers don't accept hot water?)
Solar thermal panels??
also your opinion
