Originally posted by fopoku2k2
View Post
View Post
When you use a PWM controller like you have, you have to use expensive 36 cell battery panels. Example if you used your panels in parallel on a 12 volt battery system your charge power is reduced from 500 watts to 192 watts (16 amps x 12 volts) Just call it 200 watts or 100 watts from each 250 watt panel. Use a MPPT and you get roughly 475 watts when taking conversion losses into consideration and 475 watts @ 12 volts = 40 amps vs only 16 with PWM.
So now that you know go shopping for a 20 amp minimum MPPT controller. Be careful cheap ones are really PWM, check Voc input voltages, you want one with at 100 Voc input. A good one is going to cost you more than $200.
