First I am an EE, senior IEEE member with over 30 years in the TV broadcast industry including circuit design. I have done hands on work with 750kva UPS systems but I'm new to solar power.
I have searched the forum and basically determined what I want to do is not possible so be it. I just don't understand the technical reasons.
I am installing a grid tied 10kw system in Los Angeles. (via a dealer, not DIY). I own a 8kw 120/240 portable generator with an approved panel main breaker interlock. My solar will be line tapped via one of those new Siemens solar ready panels. So why can't the generator be used as a power source to fool the inverters into operation during a power outage?
Note I realize the complexity in a safe change over system and I can construct one with the appropriate relays (power contactors) and control logic to prevent any backfeeding. That's not the question here.
As I understand it the inverters sense the grid impedance and a local generator will be too high. I can perhaps fool that too electronically. But what I don't get is why can't the inverters simply throttle back in the case of low demand? An typical modern inverter is basically a PWM switch mode power supply. It is possible to design an inverter that works this way.
Why do solar inverters have to output full capacity all the time? Can't they be made with a throttle back mode that is generator friendly? I guess what I am missing is why the need for a battery in the mix? At night the inverters simply shut down and you run off the generator?
