Hi! I'm looking to install some panels on a two story house and noticed that in addition to stand-offs that fit underneath the existing tiles, some installers just install asphalt shingles and then place the panels over them, more or less flush with the existing tiles.
This seems preferable because it...
The transition from concrete to asphalt seems pretty easy. Just drop the last layer of tiles over the shingles with a little flashing. I imagine the sides are also pretty easy. Just flashing to make sure the water is channeled to the bottom.
I found this post, which suggests some custom flashing. I don't think that's too hard, but I'm unsure of how well it will prevent water from getting under the tile. I think the second solution, installing asphalt all the way down and then placing tile over it, is better, but still pretty labor intensive.
http://www.solarpaneltalk.com/showth...l=1#post101221
Are there any other methods I'm missing that might be easier than either of these?
- Gets me some surplus tiles
- Is easier than stand-offs that sit under the tiles
- I don't need sign off from a civil engineer on the roof load
- Aslphalt tiles under panels will probably be as durable as concrete tiles
