Doubling smaller wire to increase the ampacity
  • kamflyer
    • Mar 2015
    Greetings all.
    I know it isn't ideal, but I wanted to ask your thoughts regarding doubling DC power cables to increase the ampacity.
    This would only be used for my battery jumpers. I currently run 2/0 ga for all my battery runs but am upgrading from 2 x 6V to 4 x 6V. Seeing as how I already have some from another project and to save a bit of $$ I wanted to double up 2 x 2 ga for the 4 inter-battery connections. Each of these would be approx. 12".
    Good idea or no? Safe?
    Thanks -Rob-
    Why not put the batteries in series, and go to a 24 vdc system? doubles the power without increasing amps. Many good charge controllers and inverters auto select between 12 v and 24 v.
    • Wy_White_Wolf
      • Oct 2011
      • 1179
      Can a single cable handle the load if one goes bad? If not then you've set yourself up for a disaster.
      WWW
      • kamflyer
        • Mar 2015
        Unfortunately my inverter won't do 24V (Magnum Prosine 2012) Also 24V would fry most of my DC electronics. This is in a 5th wheel trailer BTW.
        WWW
        It should handle it but will undoubtedly cause some V drop and will get a bit warm. The heavy loads tend to be very intermittent and of short duration.
        I don't intend this to be a permanent solution; just until I can get some proper cables made up.
        -Rob-
